727 Big Block Trans in a 65 Plymouth
moparcrazy
2:41 AM
california
Has someone put a 727 bb Trans in a 65 Plymouth with cable shift, will
it work ? i would love to keep the floor shift console with the original cable .
Why not? I have seen it done in magazines and a few people here have done it.
727 trans
Yes
I have one in my 65 coronet 500.
moparcrazy, if youre referring to the 65 & earlier cable shift trans, it will go right in. There is a difference in the valve body between a button shift car and a column/console shift car that you have to be aware of.
If you're referring to a post-65 linkage style trans it gets a little more complex but it can be done. I have not seen a writeup on here about doing that while maintaining the stock console shifter, but in fairness I have not looked. I did this in my '64 Sport Fury some years ago using a modified stock shifter and a B&M cable kit. It wasn't perfect but it was functional and totally hidden. I'm sure that with a rework of my modified lever lengths I could have made it right.
-Mike
'65 big block transmissions are available. Not the cheapest, but available nevertheless. Check out the transmission for sale section on Moparts.
I've got a '67 727 in my '64 Polara and retained my original shifter and console. I used the Imperial Services http://imperialservices.net/ conversion kit. You will need to purchase the cable conversion kit as well as the conversion mount. It works well.
Hmmm Imperial Services still waiting to hear anything from them in 4 months since I paid them for a speedo for my 727.
I will NEVER give up my P/B shifter!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:grin:
Took 3 years and alot of phone calls to get my cable conversion kit from Imperial Services,but I did get it........I'm sure it will take me that long to install it and get the car running back on the road.
WOW Thank you ! ! For All your help if anybody else want to comment Thanks in advance.
Imperial Services
Hey Thanks They Have What i Needed, Thank You Detroit Iron ! !
