and this applies for regular forward valve bodies also, correct?Start in first to get the tires spinning and shift to 2 without lifting, and finish your burnout.
Sorry OP to go a bit off topic here, but it's somewhat relevant.
Yes. Don't stay in 1st with a Torqueflite. Manual low to second during the tire spin. The big horsepower guys start in second.and this applies for regular forward valve bodies also, correct?
1-2 that quick. You can hear the engine pull down.and this applies for regular forward valve bodies also, correct?
But again, for the regular folks reading, starting in second is for manual shift valvebodies .The big horsepower guys start in second.
Yes.But again, for the regular folks reading, starting in second is for manual shift valvebodies .
Well, you're no fun.Sort of related, always stop the car with the brakes before shifting from forward to reverse, and reverse to forward.
I don't think you understand. 1st gear is provided when the forward clutch (rear location in the trans) is applied and the rear drum is held. In manual low the rear drum is held with the low roller clutch and the rear band. In the D selection the rear drum is held by the low roller clutch alone. Either way the components that hold the rear drum in 1st gear are both doing the same job. There is no difference in slip. The difference occurs on the 1/2 shift. To complete a 1/2 shift the intermediate band is applied stopping the high/reverse drum. The forward clutch is still applied. This creates 2nd gear. In the D selection when the intermediate band applies the rear drum is allowed to rotate as the low roller clutch only holds it in one direction only. In posistion 2, the rear band needs to release as the intermediate band applies. The low roller still overruns the same. So the only difference between the two selections is that the rear band has to release the drum if it's in selection 2. Either way the low low roller always hold the drum in one direction. So there is no "Slip" difference.Ok this explains there is a mechanical difference/behavior between starting in D and 1, and answers my question. I think I will have to better understand automatic trans to really get it.
So the gear ratio is the same, but 1st allows for more slipping, which allows more RPM and more torque?
Is this typical of more automatics of the time?
Doug - in a typical street deal, is the 1-2 shift cleaner/faster in “D” because there is only one action - applying the intermediate band, verses the two “simultaneous” actions of both applying and releasing the intermediate and rear bands?I don't think you understand. 1st gear is provided when the forward clutch (rear location in the trans) is applied and the rear drum is held. In manual low the rear drum is held with the low roller clutch and the rear band. In the D selection the rear drum is held by the low roller clutch alone. Either way the components that hold the rear drum in 1st gear are both doing the same job. There is no difference in slip. The difference occurs on the 1/2 shift. To complete a 1/2 shift the intermediate band is applied stopping the high/reverse drum. The forward clutch is still applied. This creates 2nd gear. In the D selection when the intermediate band applies the rear drum is allowed to rotate as the low roller clutch only holds it in one direction only. In posistion 2, the rear band needs to release as the intermediate band applies. The low roller still overruns the same. So the only difference between the two selections is that the rear band has to release the drum if it's in selection 2. Either way the low low roller always hold the drum in one direction. So there is no "Slip" difference.
Yes it is. Thats why many race valve bodies don't have low band apply. The 1/2 shift is seemless. It's either in 1st or in 2nd. There can't be any overlap like during the 2/3 shift.Doug - in a typical street deal, is the 1-2 shift cleaner/faster in “D” because there is only one action - applying the intermediate band, verses the two “simultaneous” actions of both applying and releasing the intermediate and rear bands?
The racecar does not use LBA. I do have one in my street car as it doesn't have a shield.I don’t remember, do you use LBA in your race car?
Absolutely wrong! KimYes, if you do a high rpm burnout in manual low and back off the gas without shifting, you can take the sprag out and do some damage if not destroy the transmission.
Sorta kinda. KimStart in first to get the tires spinning and shift to 2 without lifting, and finish your burnout.
You know, at least when I try to correct some one I prove the point. looks like you need to study up Kim.Absolutely wrong! Kim
