Plug variance like that is really odd? Especially considering you have not got it to run?YES, very strange. It ran perfectly over the summer and fall. I have spark all down the line, not a thick/blue but it does snap. A funny thing I found last night is that as I cranked and added fuel (some by bottle, some with accel pump) that I thought I had flooded it. So, I took the plugs out once again and this time noticed that there were differences between them. Four were very wet, two were very black sooty, and 2 were dry as a bone!! (they were all removed, cleaned and dried before performing that latest test) I haven't mentioned this before but the fuel at the log is reading 6 to 7 psi (which is similar to our old racecar)
Did you recheck the firing order after changing the plugs? Like a 5-7 swap or 2-4 swap at the plugs for example?
I did this once accidentally on a 318, ran pretty shitty on 6 cylinders.
I'm assuming the timing and orientation of the plug wires on the cap are correct.
