73 Satellite Body Plugs location
r0yce
9:51 PM
Munich
Hi guys,
after reading this forum quietly for some time now, I also have a question.
As I'm missing some bodyplugs I now need to replace these.
I just ordered a bodyplug kit.
Is there any documentation where all these bodyplugs are located?
Thanks in advance!
Cheers
Not at home right now though so I can't check my body service manual; But I do believe that they do show where the plugs are located in at least a few of the images albeit indirectly. When I get home I'll check for you if I remember!
I looked in my body service manual, and did not find anything regarding size and location of body plugs. With that said, its pretty easy to figure out where they go, the only two that may not be in your kit are the two metal ones that are in the rear seat floor pan, one on each side and are sealed with body sealant, and the one rubber one that goes on the center of the hump under the front of the rear seat. If you have those, the rest are pretty easy.
Found a few pictures of the interior plugs, don't have any of the trunk, but hope these help you out.
Thanks guys,
this helps a lot at first!
