- 12:17 PM
- Oct 8, 2012
- Valencia, España
and about lights... I made exactly the same.... no wires cut, just untapped, pulled out the necessary wire lenght to install the relays on the right spot, and added the "jumper wire" ( same color to make it unnoticeable after retappe them ) up to dimmer floor switch
I'm searching a diagram about the headlight relays job to be located on kick panel area I made but can't find it. Will edit the reply and post when I find it. It shows more clear the job made on this kind of job without Hack up the harnesses just untapping and installing all relays into the cab, out of heat, enviroment elements, oil etc... and showing your car as a pure stock piece from outside
Need to say this diagram I made is just ilustrative. The high speed relay is not feeded from main control switch like diagram shows but from fan lever switch.
