Hey man! I just built a V-8 Vega hatchback with an 8 1/4 that came from my '73 Dart Swinger. The Dart got an 8 3/4. Since MoPar has been using the 8 1/4 since 1964 in everything including pickups, vans, C-body tuna boats and more recently Durangos, Jeeps and Dakotas, I figured it was a better rear end than a GM unit. It has the same pinion shaft diameter as the Dana 60, 12 bolt GM and 8.8 Ford. But, the 8 1/4 came in two differential support bearing configurations depending on what vehicle it was destined for. A large and a small, which isn't really that small. The difference between the two size bearings is the outside diameter race which fits that specific housing. Everything else is the same. In 1997 MoPar upgraded from the original 27-spline carrier to a 29-spline carrier. To swap a '97 up 29-spline posi carrier is direct using the bearings for your housing. You can use a cut and resplined set of 9 1/4 5-lug axles from a pickup or van to top it off or buy custom axles to fit. I had a set from a van cut and resplined for my Vega by Moser. These give you basically Dana 60 axles. Moser tapers them just before the carrier. The 8 1/4 really is a buildable heavy duty unit. Food for thought.
