padam
I think I’m not the only one who will remember where I was the day that…
Don't be THAT guy !!!I think I’m not the only one who will remember where I was the day that…
I'm aware of the difference between the HOTCHKISS (8-3/4" ring gear diameter) and the Salisbury rear as my GTX has the Dana 60 rear. The GM 12 bolt rear uses a 8-7/8" ring gear diameter.....8 3/4 is a Hotchkiss, ( along with early chevy 10 bolt, 55-64, and 9"ford), 7 1/4, 8 1/4, 9 1/4 and Dana 60 (and 12 bolt chevy, and 8.8 ford) are Salisbury rears.
Then again maybe today is not the day.I think I’m not the only one who will remember where I was the day that…
In another lifetime, I was involved in designing ASME Code unfired pressure vessels, where material certification and traceability documents (heat numbers) are required along with writing the weld procedure specifications (WPS) and maintaining the welder's procedure qualification records (PQR) for welding the various materials and filler metals and correct shield gases, needed along with the various methods (TIG, MIG, MIG GLUX CORE, STICK, SUB ARC) and the positions used and required. WELDING is a science and a learned technique to be able to successfully join two metals, with different methods......its not a simple as grabbing the MIG gun and having at it....so to speak......the secret.....practice, practice, practice your technique and method.You should write a book
I keep telling people... it's not the weld...it's the PREP!Obviously.....NO WELD PREP......grinding out the affected area to beyond the crack depth and length.....sort of a fundamental requirement......
BOB RENTON
