although the 8-3/4 is a good rear axle for street cars you are limited to a --- very small gear ratio selection and case strength beyond 550 hp is marginal , it will break ,,, when is the question , and at the power level you are talking sooner than later .
the Dana 60 strong differential but gear changes are a pain and again limited in choice.
despite what the purists say go with a Ford 9 inch rear axle -- gear ratios 2.50 - 7.50 in increments of 10 --- drop out center section so gear changes are easier or have different center sections to swap in , parts are readily available everywhere ,
it will not be cheap but you want to do this once especially at the power level you mentioned.
helped a fellow with a 1965 440 dart measure up a Ford 9 inch for his car after breaking his 8-3/4 --
this is what i had him order from Moser Engineering
---- heavy 9 inch housing exact width/mounts for his car , with 8-3/4 housing ends so he could use his brakes ,, 35 spline axles ,, Moser center section with spool and i believe 4.11 gear --- 1350 yoke ---- the 35 spline axles were used for strength and if he ever wants to put the car on the street 35 spline Detroit lockers are available for street use .
