- 7:39 PM
- Feb 20, 2012
- Maskachusetts
Is it possible to get all of the oil out of the rear with a suction gun?
I swapped fluid 500 miles after a ring and pinion swap.
https://1drv.ms/v/s!AksXImgz5jdy0TK4f5ob4p7BFPlc
What weight/brand oil will you be using as a replacement? I should really do this with mine also.Is it possible to get all of the oil out of the rear with a suction gun?
Depends how good you are at sticking your hose in a hole Mark. Maybe you should get Submit to come out and direct you in your quest....
we have had luck with a piece of 3/8 fuel line in place of the clear plastic hose as far as getting to base and having a decent angle.
Glad you got it out, sounds like it was time.I got some 3/8" clear flexible plastic hose from Home Depot today & was able to get most all of it out. Opposed to what came out of the 4-speed transmission, the rear end oil was pretty ugly.
While I was doing ring/pinion n adding Sure grip, I drilled n tapped an NPT hole at dead bottom and put a plug in it. Gear oil change is now easy peasy
