906 heads, aluminium heads, 452 heads
Phoenix440
2:01 PM
Melbourne
Hi all
Looking at replacing 906 heads on 69 440. (Mechanic thinks the car has a cracked head as has a combustion leak and some oil in coolant).
Just looking at my options before getting the heads removed( have a spare block in case there's issues there).
As you can see from the pictures, the right side of my engine bay is very tight.
The block hugger headers have been modified for clearance against the shock tower of the car.
I wanted to install Edelbrock alloy heads but after researching, it looks like this could be impossible due to the tight clearance.
I read the heads need longer plugs than the original heads and I assume that they must be wider to need the longer plugs.
Can anybody estimate how much more room these heads take up in the engine bay?
Assuming alloy heads aren't an option, I have a chance to buy some rebuilt 452s( I've posted this now, don't want to miss them if they are a good option).
I am wondering if these are physically the same size heads and will bolt straight on? Also are the 452 valves the same size as 906,or does this depend on what size motor the heads originally came off?
As always, really appreciate any replys
What is this engine installed in? You might get lucky and find someone that has Eddy heads installed in the same vehicle.
The Edelbrock heads don't pose any issues for me in my '70 Charger. I have a buddy with a 69 Coronet and he has the Stealth heads from 440 source. His clearance is similar to mine. The Stealth heads flow better than the iron heads and they are designed to look very similar. Both sets utilize stock stamped rocker arms and shafts, stock length pushrods, etc.
I am curious though....like the guy above me asked...what the heck car is this engine in? Those headers are unusual too. The TTI and Doug's headers we often use here are not shaped like those. Are the headers something custom?
The "452" head is an improved version of the " 906" with hardened valve seats, and possibly better porting. Same valve sizes. Dimensionally identical. I use them on my 440's.
Engine is in a 1963 Dodge Phoenix, which is an Australian assembled Dodge 440. The motor sits much closer to the right side which I think is pretty standard for all models to allow for left hand drive steering. Aus Phoenix is right hand drive but motor sits in the same position in engine bay
Just some info on if you going the aluminum head route I think the only two heads that come with straight spark holes are the Stealth heads and the E Street 84 CC Edelbrock heads the rest come with the angled plugs which might or might not work in your application.
Also, even if there are alum heads with straight plugs, they use 3/4" reach v 3/8" for factory iron heads. So although they might be 'straight', they might not be positioned in exactly the same spot. Changing plugs in that engine bay looks like a nightmare...
Are your motor mounts in good condition? You may be able to shim that right side mount to gain more clearance.
Mike
Can get the plugs out on the right side using a cut down tube spanner to get to 4 and 6 and short 13/16 spanner.
Thanks for reply. I'm not sure what brand the headers are, but the rt side have been cut and rewarded by an exhaust shop to fit the engine bay.
Headers are standard block hugger, not sure of brand. At 21.00 minutes, shows the modifications to make them fit, done by the guy who originally did the big block conversion.
Hi all
Looking at the first picture you put up it looks your right hand is resting on the fuel line.
In the second picture it looks like the fuel line (hose) is getting a little wavey from the heat.
In the last picture it looks like the fuel line is resting on the piece of metal which is also physically touching the header pipe.
I would reroute that fuel line.
At first, it didn’t occur to me that being where you are, you’d have to convert the car to RIGHT hand drive.
Holy cow, that would be difficult. The engine and transmission in these cars often sit almost two inches off center to the right for left hand drive models. With headers, I have some trouble changing spark plugs on the 2468 side. I can only imagine how cramped your car must be with steering linkage sharing space there. You guys must really have trouble with the slant six engines too! Over here, service to a slant six engine is easy if it is a starter, intake or exhaust but if it is related to the distributor or spark plugs, it isn’t so easy.
I think the 452's is the right answer for you.
If you really want aluminum heads (they'll make more power than stock 452's, for sure) I'd revert to the 440 source stealth.
In your research, study which heads have raised exhaust ports. Would be a nightmare for your situation.
