cheeseburgerhead69
96 Ram V-10, crankshaft position sensor stuck. I've lubed it up for days, wouldn't budge, ended up breaking off FLUSH with the engine block... tried melting the plastic away with a soldering iron, as someone mentioned it worked for them. No luck, drilled a hole in it, screwed in an eyelet, connected it to a ratchet strap, got as tight as a banjo string, Nope, that hasn't worked...been under pressure for 2 days... tried heating up the block around the sensor with no luck... So any suggestions guys ?? Anyone know if the sensor gets its signal from a tone wheel, or from one lobe on the crank ?? Half tempted to knock it into to the pan and let it live there as long as there is not interference from a 360 degree tone wheel that might be damaged. Dont really want to drop the pan and knock it out from the bottom ...
