Danmc77
It's been years since I last worked on my charger, but last time I did, I had a shifting issue:
68 charger 440
A833 4 speed Hurst shifter
Rowing through gears just cruising - no issue at all. Smooth and clean shifts.
When I get on it, 1st to 2nd shift doesn't work. Just won't go into 2nd at all. I can jump to 3rd no problem. I can slow down and downshift into 1st no problem.
If I remember correctly, I would have to slow down, go back into 1st and it would go through gears again fine if not flooring it. Almost like resetting it. But if I accelerate hard again, it still won't let me get into 2nd gear.
I did check out the linkage and tried to reset it with a pin and starting from scratch, but that didn't do anything.
Also, I'm doubting it's linkage since it shifts fine when accelerating at a more moderate speed.
I will add that prior to this issue, I had tranny out to replace clutch with a McLeod performance clutch. I had a hell of a time mating tranny and engine even with the alignment tool. Eventually got it to mate with bellhousing bolts drawing them together. I understand that's a red flag, but again it shifts flawlessly unless I'm flooring it, and it's only 2nd gear issue.
Any thoughts?
68 charger 440
Any thoughts?
