- 10:38 PM
- Jul 1, 2015
My '70 GTX RS23V0A****** had the same issue. When the clutch was replaced (Macleod) and the flywheel resurfaced, I had the transmission (A833 18 tooth spline) rebuilt (by Allen Driveline, Pittsburgh srea) all bearings were replaced including the uncaged needle roller bearings and thrust washers, all sliding sleeves and the synchro rings and dog houses and the 2nd gear with the brass teeth (origional brass teeth were worn with burrs on the point). The shift forks were inspected where they contact the synchro sleeves and lever pivots replaced. External linkage adjusted per FSM. I use 85W-90 synthetic gear oil (Mobil One). The release bearing was replaced: the pilot bushing was replaced. It was an expensive overhaul (~ $2.5k labor and OEM parts)......was it worth it???......absolutely ....transmission shifts smoothly under all circumstances .....It's been years since I last worked on my charger, but last time I did, I had a shifting issue:
68 charger 440
A833 4 speed Hurst shifter
Rowing through gears just cruising - no issue at all. Smooth and clean shifts.
When I get on it, 1st to 2nd shift doesn't work. Just won't go into 2nd at all. I can jump to 3rd no problem. I can slow down and downshift into 1st no problem.
If I remember correctly, I would have to slow down, go back into 1st and it would go through gears again fine if not flooring it. Almost like resetting it. But if I accelerate hard again, it still won't let me get into 2nd gear.
I did check out the linkage and tried to reset it with a pin and starting from scratch, but that didn't do anything.
Also, I'm doubting it's linkage since it shifts fine when accelerating at a more moderate speed.
I will add that prior to this issue, I had tranny out to replace clutch with a McLeod performance clutch. I had a hell of a time mating tranny and engine even with the alignment tool. Eventually got it to mate with bellhousing bolts drawing them together. I understand that's a red flag, but again it shifts flawlessly unless I'm flooring it, and it's only 2nd gear issue.
Any thoughts?
BOB RENTON
