Currently, my car is taking a bit longer then I had thought it would, but that's how life goes sometimes.
So I definitely don't have the cash for a stroker kit for my 383 or 440.
Both are very good running engines, and will have to due for a bit.
I do daydream about a "B" engine 400, based 500CI stroker, and make it look like the stock 383.
I don't want to change to much on the #'s 383, but what would your thoughts be on the stock 69 383, with a set of 440 source heads, VS a 1973 steel crank 440 with the same heads and a cam swap?(both running headers, and same highway/cruising rear gear )
Would the hp of the 383, beat the torque of the low compression 440?
I am leaning in favor of the 383, the last low compression 440 I had, was a dog.
If I do decide to use the 440, I will most likely, run the 383 for a bit as I save up to toss a set of pistons in the 440, and rebuild it, but I figured I would ask just to get thoughts on running the low compression 440 vs the 383.
