- 10:40 AM
- Dec 14, 2008
- Long Island,New York
A few more from one of the best MOPAR weekends of my life:yes:
Let me share a little story about the Lee Smith and The Melrose Missle.
In 65' The Melrose Missle came to Cordova Dragway(Cordova,IL) to run at the World Series of Drag Racing. In the finals he ran against a local racer named Lee Smith. The Melrose Missle was one of the top cars that year if not the top and was a HUGE favorite. The Missle red lighted and lost to Lee. After the loss he was total pissed and was saying he would never come back and he was cheated.
My dad tells me this story everytime he sees a pic of Lee Smith or The Melrose Missle. Tells me that is was one of his favorite memories from back in the day.
Check this out if you'd like to read the factory tech report on the altered wheelbase cars. The first link is the document, and the second link is an article on it by Steve Magnante.
http://www.moparmax.com/features/2006/images/05-report/report.pdf
http://www.moparmax.com/features/2006/i_5-report-1.html
I would NEVER just make something up (if you knew me, you'd know better). Also,no one is stating these cars were assembled on a factory assembly line, "at the factory".... no one is saying that... The 1965 bare bones 'bodies' were pulled off the assembly line, and eventually ended up (I believe) a building next to Highland Park Engineering Center, (which was 'factory backed & financed). I believe the work actually started on these 1965 models in Oct 1964, - Dec 1964. I respect your input, and if I find 'more' evidence & facts to verify your statements that you mentioned of the contrary, I will post those facts. Thanks, and I respect your input... NOW about the post...., does anyone know anything about the 'post' on the hardtop bodies????????????? Check the picture of Lee Smith's 1965 Plymouth with the door open, that was posted earlier by HEMI-ITIS..What do you base this "theory" on? There are factory drawings and parts sheets available that were made available when these cars were new so people could build their own. Is this indicated there or are you making this up as you go along based on any kind of information that points to this?
I stated earlier in this thread that the Alexander Brothers shop in detroit built the first FXers and that NONE were ever built in a Chrysler factory. I offered proof by example of a specific book on 1964 Hemi race cars that was written by some one that researched all of this extensively. I was ignored or poo pooed. As indicated above, why would the factory make build plans available to build your own if they were building them in house? They were too labor intensive and too many deviations from standard assembly line models to do in house and that is why they were job shopped from the beginning.
Some more info..........Gives a list of who got what car.........
Most historical sites say there were 12 factory AWB cars built; 6 Dodge and 6 Plymouth. But then other racers made an unknown number of copies. Some hardtops, some sedans. Some feel the original hardtop "test mule" was later made into the Golden Commando Club car. We're not sure. Supercar President Scott Dahlberg has spoke with many of these original drivers recently, and sometimes he does gets conflicting information. And that's right from the drivers. Of course, this all happened 45 years ago now. Does anyone remember everything from that long ago? I don't. So here is what has been complied for the real cars...
For the original 1965 Plymouth Hardtop AWB cars:
AWB Test Mule
Al Eckstrand & Forest Pitcock, Golden Commando Club Car
Butch Leal, California Flash
Ronnie Sox, Sox and Martin
Lee Smith
Cecil Yother, Melrose Missile
The bare bodies (real cars) were constructed at Chrysler's Los Angeles assembly plant, and shipped to an outside vendor for acid dripping. This process allowed the body weight to be reduced by 200 pounds. The mods were pretty extensive, so they could not be done on the regular assembly line. The bodies were then shipped to a contractor specializing in ambulance conversions called Amblewagon, and they were in Troy, MI. Obviously the forward relocation of the front and rear axles caused considerable sheetmetal work (unibody construction), and the front wheels were moved forward by installing special lower subframe rails and sectioning the inner fender panels. The upper control arm pivot and shock mount were moved 10" forward. A lightweight stainless steel K-member also bolts on the new frame rails 10" farther forward. The steering linkage was extended and longer torsion bars installed to compensate for the relocation. To move the rear axle forward, the floorpan was sectioned and a 15" section removed. The quarter panels were sectioned, and the standard wheel openings moved forward the appropriate amount. Sheetmetal filler panels were added to the sectioned areas, and everything was welded back together. A cross braced four point roll bar was installed for chassis stiffening. The front bumper was also fiberglass, and the rear bumper remained steel to maintain rear end weight. Inside the car were lightweight bucket seats on aluminum mounts, and carpeting. These cars weighed just 2,800 pounds when delivered, and the weight distribution was the best possible, with 56% on the rear.
The power for these was the 1965 A990 426 Hemi, and an actual A990 S/S car was cannibalized for the engine, driveline and interior for each car. They cranked out over 500 horsepower when carburated. Later during the 1965 season Chrysler engineered a fuel injection system using Hillborn injectors, with reworked mid-range and high-speed circuits. The velocity stacks varied depending on the transmission type, with tall 13-1/4" stacks on TorqueFlite cars, and shorter 7-1/4" stacks on 4-speed cars. Performance was increased with this system over the dual Holley carbs, from mid 10's, to high 9s. A speed of 140-mph were not uncommon near the end of 1965. They were the most notable wicked drag cars ever built, and the fans loved them!
For 1965 Dodge AWB cars:
Bobby Harrop, The Flying Carpet
Bub Faubel, Hemi Honker
Dave Strickler
Dick Landy
Jim Thornton and Mike Buckel, Ramchargers
Roger Lindamood, Color Me Gone
The bare shell was assembled in Ca. Not complete cars Landy over saw the acid dipping of the Bare Shells.They were then shipped back to Detroit for conversion.
Try not to read something into it that isn't there...The reference to "cannibalization of a A990" car is just a reference to taking a A990 motor . Only meaning they took a A990 Hemi motor to use for these cars in '65. Also the torsion bars were stock Imperial Torsion bars that were used on the '65 cars. No modifications at all on the bars......just plain old stock Imperial torsion bars. That's it. Also, nobody is saying that they used A990 cars to build AFX's out of, and nobody is saying the A990 cars came out of L.A.. Your just assuming that. READ FIRST SENTENCE OF THIS POST.
