robocop1971
Cranky I appreciate the help; I had the brackets turned wrong..... I apologize for coming into this post with a question that someone else started. Thanks again
You'll get more than 3 1/2" more height by placing the rear under the springs plus you'll have to mess with the correct angle so the U-joint won't wear out from too much angle....Yeah i'm still not sure what to do the Spring are again brand new from Mopar XHD from
Mancini less than 2000 miles on the car from Resto . Putting the springs above the axel would do the trick but I assume I would have to weld in new brackets & not sure if I whant to go there. I notice Original factory photos & my car sits correctly I have 205 65 15 all around maybe a taller tire would help . again I can live with it but I also notice If someone rides in the backseat I can really notice the difference in the ride .
I would like to lift the *** end of my 67' GTX up an inch or two I have new XHD leaf springs & new XHD Monroe shocks with a coil spring on the top of the shock with no real extra lift.
What opinions does anyone have on them Yea or Nea !!! The car used to have adjustable shackles in the rear of the leaf springs till I read that those are verry bad for torsion bar cars. then I converted to OEM style shackles & lost that extra 1- 2 inch extra lift in the rear that I liked soo much Thanks
:headbang::headbang::headbang::VB toast:125 psi with air shocks ??
.....might as well use solid struts instead of air shocks and springs.
Band aid yes, the upper cross member where the shocks are held in, maybe. Rusty old cars will have a problem.Using air shocks to lift the car puts a load on the upper cross-member that it was not designed to handle.
And it is just a band-aid.
Bingo. While the front end can take a little lift at the rear without adjusting the front, IMO, as said before, proper usage of equipment is often ignored.And longer shackles allows the rear of the spring to move sideways a lot more under cornering loads. And it changes the pinion angle as well as the caster on the front end.
Long shackles are not good for any kind of a leaf spring car no matter what kind of spring is up front but raising the rear an inch or 1 1/2" doesn't seem to bother them but the best way is to re-arch the springs.
LOL, That is great.
True! Like mentioned earlier about side to side swaying movement. Longer shackles are another band aid.
