Alcohol in gas
Have you tried running fresh gas through the engine (running I mean) ???
Or is this a project on the bench?
:xscuseless:
If this is a carburettor on the bench, you could try flooding it with methylated spirits.
That will remove all gasoline type liquids.
What are we working on? Car or generator/weed eater/small equipment?
Run the car with ethanol free gas container connected fo fuel pump
Off the engine? Carter turn it upside down and drain it. Holley remove a lower float bowl screw from each float bowl and drain.
Alcohol ?
AAAHHHHH....at the end of a long and trying day......a nice single malt Scotch, double of course, neat, water back or a nice Tennessee Sour Mash Sipping Whiskey......Black Jack Daniel's, the same way, or a blended Canadian, CC or VO......or......????....what ever suits your fancy.......Cheers.....
BOB RENTON
:bananaweed:
BOB RENTON
I'm that I worded my question poorly. I'm looking to get the leftover crab from the alcohol out of the carburetors. I'm talking about a car and a generator. Is there any way to clean the gunk out without tear down?
Has it already turned to gunk in the carburetor? Has some time passed since it was last run, like 3-4 months or more?
If it was recently running then run good gas through it by starting the engine with good gas going in the fuel line.
