Question regarding upgrading my current alternator. Don't know what the amps are or anything about it, but I want to upgrade it with a higher amp one. Currently, the alternator is hooked up this way: hooked to the battery post connection is a black and brown wire, and the other connection on the back of the alternator (female slip on connector) is a green wire.
From Year One, I ordered a Powermaster 75 amp, single pulley double wire alternator. I got the alternator, and on the back is the battery post connection, and then there are 2 male connector tabs. Now I'm confused, I only have the one green wire left to connect. Are the 2 male connectors interchangeable so I can use either one for the green wire depending on positioning of the alternator?
