Landon
Bob, is having all these wires tied together going to cause issues?NO....The BLUE wire provide the electronic voltage regulator the system's reference voltage of the voltage present at the battery AND the switched source from the ignigion switch. The GREEN wire RETURNS the current psth from the alternators field.....blue wire power going in TO the alternators the GREEN wire, via the alternator regulator to GROUND, thru the internal transistors. IT HAS NOTHING TO DO WITH RACE PROPOSES AS STATED.
NACHO....you need to not to explain or exemplify sonething that is incorrect....if you do not understand the how the system operates.....just ask.
BOB RENTON
blue (run) to regulator, Brown (start), MSD red, dist. red, and new wire from regulator to alternator
kind of a mess. I don't have a resistor, and the MSD box and dist. need both the blue (run) and the brown (start) wires. The regulator apparently also needs the blue (run) wire
