500stroker
- 1:58 AM
- Aug 19, 2012
- Lake of the Ozarks, MO
I have a 66 Satellite with stock wiring.
I will be adding cooling fans which will draw about 50 amps.
I dont have the money to upgrade to a higher output alternator and rewire the car.
The output wire coming off the alternator was butchered by a prior owner and showed signs of being hot at one point in time, these has been corrected and now is in good shape.
I know putting a big fan load on the stock alt. and wiring is not the best but its all I got to work with.
Can I simply add a new 8 gauge wire from the alternator directly to the positive side of the battery while keeping the stock wiring in place? My thought here is to take some of the load off the old wiring and the factory dashboard ammeter.
Will adding the wire drain the battery when the car is not in use?
Am I on the right track or just nuts.
