mikeynags
Hi everyone,
Today I started up the RR to see the ammeter discharging and my voltmeter only reading about 11.8 volts. Battery reads about 12 volts between the terminals when the car is running. As soon as I pull the negative cable the car dies. I am measuring about 20 volts on the output of the alternator itself (which I bought brand new this summer along with a brand new voltage regulator) and I also measured 20V on the connector going into the firewall. I pulled the voltage regulator and measured 12 volts DC (with the key in the on position) between both pins and ground per the instructions of the troubleshooting section in the Mopar service manual. Also, I changed the VR and no luck either.
Any ideas on where to look next???
thanks,
thanks,
