440roadrunner
Okay...need to ask a dumb question...
I have a copy of the 'fleet/taxi' wiring bypass diagram. It's also for 64s, like I've got. Question is on the regulator. Even on the 64 wiring, the fleet diagram shows using one of the later transistorized(?) regulators. Is that a must, or will the bypass work using (lol) one of the regular regulators???
The type of regulator has nothing to do with the output circuit. It IS "required" to use a solid state regulator with a Mopar breakerless ignition. Having said that, most if not all replacement 69/ earlier regulators are actually solid state.
What IS relevant to the regulator is voltage drop between the battery and the regulator. "Fixing" the output circuit drop (bulkhead connector and ammeter problems, AKA Mad) fixes part of the problem, but ANY drop between the battery and the VR will cause that drop to be ADDED to the charging voltage.
The general (factory stock) circuit path is battery.........starter relay.......fuse link.........through the bulkhead........through ammeter.........to harness welded splice..........to ignition switch connector........through the switch.........back out the switch connector (on IGN1)..........back through the bulkead.........and to ignition and VR Ign terminal.
So ANY bad connections in this path all added up is the voltage drop, AND anything in the GROUND circuit. This is easy to check. Key in "run" engine stopped. Measure between battery POS and the VR ign terminal. That reading should be VERY low, the lower the better. That is the voltage drop on the "hot" side, and should be less than .3V (3/10 of one volt)
Check ground side, engine running and charging, fast idle, and warm. Stab one probe into the top of the battery NEG post, and stab the other into the VR mounting flange. Voltage should "lower the better," below .2V and zero is perfect.
