doug glenn
patient is 65 satellite big block. Has been upgraded with dual field alt. and electronic voltage regulator. Recently noticed ammeter spiking to full charge? for maybe 1 minute then dropping back to normal. When this happens tach reading drops to less than half correct rpm. At first it only happened occasionally, last sunday took a 100 mile round trip & it started spiking more often(a lot). Also lost a turn signal bulb. I'm leaning toward voltage regulator going bad. Had park lights on on the way back, then realized I had lost turn signal. What you guys think?
