And So It Begins - Tremec TKX Conversion Into A 64 Polara
That’s what I was told that was needed to be done also with the treatment to the gears and sliders. We’ve got a local well known transmission shop that specializes in these modern manual transmissions, RPM Transmissions, Anderson Indiana, I’ve never asked them what they charge but I’m guessing it’s not cheap.
The carbon Fiber blocker rings & brass pads were around $250... The Micropolish & Cryogenic Processing was about $350... ( I could have easily doubled that by doing every gear, I only did the sliders & the gears that lock to the sliders) I didn't include those in what I spent to do the conversion cause they weren't really necessary... I did the tear down & reassembly so that was free... There are no gaskets, it's assembled with sealant..
The Tremec in my car shifts fine when cruising but yeah, the 1-2 shift above 6000 rpms isn't good. Mine is the last of the TKOs that Silver Sport had in stock as the TKX was being phased in. I was told that the TKXs all had the upgrades for improved shifts up to 6500 and that mine could be modified at extra cost. I chose to take it as is.
I didn't feel the need to run it past 6000 with the '528 cam I used to have since the engine peaked well below that. The too big cam I have now is just pulling hard past 5000, 5500, 6000 so it is tempting to run it well past 6000 but then when I upshift, it is as if a bar slapped across the 2nd gear gate because the shift lever just stops there and won't go into gear until the rpms drop. Oddly, if I run it to around 6000-6100 or so, it slides right in but much above that and I'm blocked. No grinding, just no movement into the gate.
I've been planning this conversion for 2 years now. I purchased the complete kit from SST Transmissions. For those who are interested, the complete kit was $5700 USD shipped. I've asked for a lot of advice and guidance on this forum which has helped me a lot, and it's probably not the last of it either - I've already run into two glitches. Anyhow, here's my story ----
Started the conversion last week. Taking out the front seat and because the car is a convertible, dropping the top makes interior access a ton easier.View attachment 1788464
Photo of car before I started.
Next the dash comes out for easier access to change the pedals
Pedal assembly removedView attachment 1788475
I had a glitch with the factory 4 speed pedal assembly - I thought the pedals I got with the car were from a 65 B Body, but they turned out to be from a 63 - there is a slight difference in the steering column bracket attachment - see this link to see how I solved this item - 64 Dodge 4 Speed Pedals - Install Issues
As per kit instructions, I removed factory clutch rod pin on the clutch pedal and installed supplied adjustable rod with new pin. I ground off the weld and the factory pin was knocked out.View attachment 1788488View attachment 1788489View attachment 1788490
After mocking up the new pedal assembly and hydraulic slave cylinder in the car, issue number two is apparent. Things don't line up and the connecting rod is to short.
View attachment 1788494View attachment 1788495
I sent a note to SST today with a few pics and will be on the phone with them tomorrow to try and resolve this issue. More to come!
Wade at SST suggested that I move the pedal connection lower on the pedal shaft. I was wondering if anyone else with an early B Body has done this. If so, a couple of pics would be helpful.
I don't think it's an easy swap from to TKO to the because on the TXK they use a Chevy bolt pattern. May have to change bell housing, unless an adapter is available to make it work. Unfortunately it seems to be a Chevy world for the after market.
Mine had a very early Keisler TKO. Got an SST, easy swap with existing interface per my Tech. Much improved 2-3. Push straight forward and get the H out of your head.
Absolutely. I shifted from 2nd to 5th several times because I pushed UP and over to the right like you do with just about any 4 speed. The gates are closer in these transmissions.
With the price you listed, did it include any discount from them? The every once in a while offer a discount and jut recently offered $300 off. I actually have a Kiesler install from the early 2000's. Back then it was about $2500 with the Tremec 3550.
I purchased my SST TKM 6 speed kit from them 4/01/24. I got the full kit less drive shaft and pistol grip shifter. It included…
Bell housing
Flywheel
Clutch
Hydraulic clutch kit
Rear trans mount
Speedo cable
Rev light kit
All fluids
It was an everything needed complete kit except for someone else to pay for it.
Sure wished I would have started buying parts a long time ago! They were nice enough to give me a $200
Discount though. Argh
Bell housing
Flywheel
Clutch
Rear trans mount
Speedo cable
Rev light kit
All fluids
Did it come with the clutch and the brake pedal?
Rather than using the original clutch linkage hole to mount the clutch master cylinder as per SST instruction, we cut a hole and mounted it up closer to the brake master cylinder. Made the connecting rod angles doable. 64 plymouth savoy.
It’s something I’ve considered. I’ve sent pics and additional requested info. to SST and they are looking to make some type of adaptor for me. I do find it odd however, that I’m the first person with an early b body to enquire about this issue. Surely I’m not the first person to order their kit to fit a 62 - 65 b body.
After being away from my project for 3 weeks, it's time to get grease under my finger nails again. In regards to my pedal mounting and ratio issues, I've been working with SST on some kind of remedy. They have been very responsive to my issues in this regard. I'm confident that we will find the correct solution. Having said this however, this kit was sold to me as basically "bolt in" package - which as I'm finding out, is not. I understood that there would be install issues, but this is a major issue - if pedal angles / ratios are not correct, you're going to regret it at some point.
So while I await for the above issues to be sorted out, I have moved on to the other tasks at hand - auto trans removal. The trans fought me every step of the way. Had to cut the H pipe because it was 1 inch to forward to clear the tail shaft of the trans. Had to unbolt the drivers side header to gain clearance and many other small details, but she's finally out.
That car looks clean underneath.
With the auto trans out, it was time to tackle fly wheel and bell housing runout.
I cleaned all the paint / rust on the back of the block where the bell housing mates to it as well as cleaning up the crank flange.
Next I made two temp. studs to mount the flywheel - because that thing is heavy!
After mounting the flywheel, I installed the bell housing, again using 2 studs to help align. I then set up a dial indicator to measure flywheel runout.
Total runout was .0015
Next I measured the bell housing runout - I was hoping it would fall between specs (.005), but lucky me, it spec'd out at .006. Removing the existing dowel pins is going to be ugly - vice grips are not going to do the job. I pray I don't have to remove the engine.
You can see this nifty tool I made to hold the dial indicator - it's not my idea however, 1 Wild R/T gave me the idea - see link - Bell housing runout
Todays job was to remove the factory engine block dowels. Vice grips didn't budge the "long" dowel and the other dowel only about 1/8 inch proud of the block.
After scratching my head for 15 minutes, I decided to weld a washer to the dowel.
Then, a nut was welded to the washer.
I then used a screwdriver as leverage behind the washer while turning the nut with a socket.
They both came out easier than I thought, which was nice. Sometimes things go your way.
I received my offset dowels (.007) this week and installed them. First crack on the dial indicator read .005 TIR - so .0025 total run out.
I know that I'm within required specs (.005), and I'm at .0025, but I may try to get the numbers closer to zero if I can. There are members who have struggled with getting their numbers within specs and have spent a lot of time getting this right, but maybe the stars were just lined up for me.
While I have the trans out, I took the liberty to change out my oil pan from a 4 qt, unbaffled 187 pan to a baffled, 6 qt max wedge pan.
Unfortunately, I was unable to keep my windage tray - they don't agree with each other.
As I was installing the new pan, you guessed it, I pulled the threads out of the block on the last pan rail bolt, which also happened to be the hardest one to install (above the cross member). I wasn't going to accept engine removal to fix this, so I was able to install a bolt that was longer than the original and was able the catch enough "good" remaining threads. The last few turns of the socket was a little nerve racking.
