Another 16v question
bobs63wagon
10:20 PM
Minnesota
Getting ready to get this thing started. You guys running 16v systems do you increase the gap on the plugs with a 16v system. I have a MSD 7AL-2. I know to check the timing to see if that has changed and check fuel pressure with the fuel pump using 16v. I thought that someone mentioned they had changed the gap on their plugs. Just curious. Thanks.
Getting ready to get this thing started. You guys running 16v systems do you increase the gap on the plugs with a 16v system. I have a MSD 7AL-2. I know to check the timing to see if that has changed and check fuel pressure with the fuel pump using 16v. I thought that someone mentioned they had changed the gap on their plugs. Just curious. Thanks.ON
The only thing I did was to set the fuel pressure. Been running 16 volt 4 years.
Doug
