benno440
Hi Guys,
I have a 68 charger with a 76 block 440.
I rebuilt the motor, everything in the engine is new except the stock cast crank and conrods.
Has new bearings throughout, KB stock size pistons & rings, lunati cam, comp cams timing gear, hyd lifters and comp cams pushrods, 440 source ported aluminium heads, comp rockers, 440 source aluminium water pump, melling high volume oil pump, 9 qt milodon oil pan and high flow pickup, tti 1 7/8 headers, msd electric ignition, edelbrock performer rpm intake, 770 holley, 11" billet flywheel, powermaster starter, march serpentine pulley kit.
The engine has only had the cam run in, and has not even seen the road yet,
NOW, my problem, the engine ran perfectly, the compression on all the cylinders were good (around 150-160), oil pressure is good idles around 75 psi, temperature is good thermo fans kick in at 180 degrees and then cools it down, BUT, some reason the engine is extremely tight with all the plugs out it is really hard to crank over as in it feels really tight, AND it blows a shitload of grey smoke out the pipes and by alot i mean it fills up my backyard.
Anyone have any ideas or suggestions, even though it seems really tight it still runs alright sort of, but too scared to start it anymore as it wasnt this tight when i first started it.
