Any Pontiac fans?
I had a 70 GTO and a 75 Trans Am, both 4-speed, back in the 70s. The GTO was a nice car with a great exhaust system with Thrush mufflers. The Trans Am was a dog off the dealer lot but after an aluminum intake, re-worked carb/distributor, Ram Air III cam and Ram Air IV rocker Arms, headers, open shaker scoop, 2-1/2” 455 SD exhaust system and a change to a 3.73 rear, it ran pretty strong. If I were going to look for one today, it would probably be for a 65 or 66 tri-power.
Pontiacs? Excuse the old crappy pictures, I lived for them in the 70’s
74 Trans Am, 73 Grand Am, 73 Catalina, 68 Catalina
All the Pontiac 400s in 79 trans ams had 4 speeds and were the higher HP 220HP W72 engine. The factory crome valve cover make that car appear like it is pretty original yet. For the automatic transmission T/A in 79 the biggest engine was a 403. I have a 77 4 speed TA that is pretty original yet, fun car to drive, picture is from last fall.
Looks to me for a price, as is, not running, with some of the rust my guess is it would be worth around $14K. It didn’t look like a special addition L-82 car, take that price x2 if it is. The price increase on those second gen trans ams over the last 2 years is shocking. Running and cleaning up past 20K, it is equipped nice. Total restoration they are worth as much as most 60s muscle cars.
Had a lot of fun with this '74 Formula 400 4 speed that I bought for $500 when it was ten years old. I put on a '73 front bumper. It handled quite decently.
Also had a blast with this 1972 LeMans with factory 455 HO. I had absolutely no idea how rare it was back in 1983, I bought it for $1000. Originally orange, I painted it white. It had no rust at all, anywhere.
Owned a 77 and 79 T/A, also built a 75 and 73 for friends. as other have said, the timing chain is the weak point of this era 400. Being a 79 and factory 4 speed, it should have the 400, and appears to in the pics. Pontiac was basically out of 400's by the 79 model year, and the 4 speed cars had priority. (Don't see the oil filler on top of the motor as you see on the Olds 403. that being said, if the car has headers, plan to get factory manifolds, as the headers are so close to the starter the heat kills starter solenoids, (trust me on that one). The door gaps on a T-top car concern me, as others said, the cars were not that rigid even without T-tops (found that out doing the auto-crossing/road racking thing), so I would take a very close look at the floorboards/floorpan. It appears the car is resting on the suspension,(fronts on ramps and jackstands appear to be under the rearend housing). and most concrete pads are relatively level, so I tend to not think that contributes to the doorgap appearance. Cannot tell from the window sticker if this was a "stripe delete" car, I would be looking very closely for evidence the car has been painted. Applying the bird is not extremely difficult (I made a career of it), but it would be tough if you only put them on once a decade. If the window sticker does not specify "stripe delete," I would be looking very closely at the windshield/rear window trim for signs it has been removed, as well as the screws that attach the frames around the headlights. A paint job might also be why the grilles are missing. Check in the trunk for patchwork/bondo in the lower quarters, that and the rear window corners were the water traps on these cars. Good luck, I'm on the fence about looking for one of these too.
Almost every day, while riding my bike to high school in Richmond, I rode past a 1969 Trans Am convertible parked by the curb. Neat car, I thought. A few years later I saw it in the 'Buy And Sell' for $6,000.
They're worth about a million dollars now, only eight were made.
