I watched the Uncle Tonys Garage video on painting the inside of the engine, and he made a point I really had not heard before, for coating the engine inside. I was to make it easy to spot and clean out debris that may have gotten into the engine. Thinking like if doing an intake swap, and gasket material got in the valley?
Eastwood sells a quart of brush on Glyptal for $50. I think I'll try it, just to see for myself how it is.
Bought a bag of Cork bottle stoppers, size #11 0.828" to 1.062" to use for masking off the lifter bores.
Just thinking of things to do with the 1966 year 440 block that was given to me. Right now it is 0.040" over and the bores didn't clean up all the way.
After measuring the small area that had not cleaned up with a dial bore gauge, it looks like they will cleanup at 0.055" over (4.375").
Before that, I will ultra-sonic check the bore thickness. Not going to be a race engine, just a mild pump gas 512 stroker, thinking around 550 HP?
I have my old, rebuilt Brodix B1-BS on the shelf, so thinking of using those heads as I have the 1.6:1 rocker arms for them too.
Also thinking of using a Holly Street Dominator that I already have, and for hood clearance.
I have many of the parts already that I either ordered extra or were not used on the last stroker engine.
Have oil pump, rod bearings, SFI damper, gaskets, intake, carb, Aluminum water pump housing and pump, timing chain set, and other small stuff like block plugs.
Have a unbalanced RPM 4.25" crank, and the 7.1" I-Beam rods, and ICON dished pistons (4.375")
Still need main bearings, Main Stud kit, maybe a head stud kit (depends if I find all the old head studs?), Have a good used timing chain set and cam button, but maybe just get a new set? The pricy parts would be cam, lifters, pushrods, and springs. I could take the PAC-1325 springs off the old Victor MW heads, but I think they might be too high pressure for the mild cam I'm thinking of using. Have two old and bent high volume oil pans that I might use it they don't leak after pounding them back into shape.
Anyhow, just dreaming up a plan for the 440 at 3:30 AM while stressing out that my wife is in the Hospital with a 9mm kidney stone, and my daughter is in the hospital because she had SI fusion surgery today.
