andyf
Yes, buy a Hyperspark distributor. They Hyperspark will let you control the timing from the Sniper. That gives you a digital timing curve, vacuum advance, start retard, rev limiter, etc.Let's start over. If I buy the distributor that goes with this ignition system, then I can delete the resistor.
Does that make any of this easier?
You need to tie IGN 1 and IGN 2 wires together and then have them connect to the pink wire from the Sniper, Hyperspark distributor and the Ignition box. The blue and brown wires provide power for start and run. Your system needs power during both start and run which is why you tie them together. The three pink wires are all trigger wires and they need power during both start and run. Here is a Sniper install that I did:
