kaj750
1. I'm new to building cars this old. I've spent my life working on anything from the 90s and later.
2. I'm still learning the vocabulary, so when I hear ammeter, I don't know where or what it is LOL (I assume it's the actual gauge in the cluster).
So, I have a Sniper 2 installed on my '69 Charger and need to figure out the wiring. My car appears stock. I can't really confirm as I'm uneducated on the subject, but I even have the resistor on the firewall for the distributor and all wiring seems really, really old and original. See pic below for reference (the mystery wire tap has been removed and wiring seems to be okay).
3. I bought the PDM for the Sniper and am aware to get power from the alternator side, vs the battery side. So, do I just grab power from alternator post? If so, don't I already have a mess of wires on it (see pics below) There are two leads coming off the alternator post, now. One lead goes towards a module on the engine side of the radiator support, above the passenger headlight. The other lead goes back into the harness and up towards the firewall. Is it safe to add another wire? Pic below for reference.
4. If I run power from the alternator to the PDM, how does the fuel pump and Sniper ECU, which run off the PDM get power to start the car? It will have a 30a fuse inline and 10g wire.
5. The PDM needs switched power. I can just run it from the "radio" spot of the fuse box?
6. My water pump has a port on top. I thought it was 3/8" so that I could install my coolant temp sensor, but it looks quite a lot bigger than 3/8". Can anyone confirm? Pic below for reference. If it won't work, then I'll be adding an adapter plate to the thermostat housing with a 3/8" port. I just don't like the idea of another potential spot for leaks. I do not know which part number water pump I have, but it looks to have one on the front. I can get it, if needed.
7. I plan to run a 10a fuse from the PDM to the fuel pump. Overkill? Will also use 10g wire.
8. Where exactly do I want to get the tach signal for the Sniper? Negative post on the coil? I see a brown wire that I believe is the tach signal for the gauge cluster.
These are the last things holding me up from starting the car. I don't expect anything for free these days, so would be willing to pay someone to walk me through this. I can't imagine it would take more than an hour or two at the most. If it's easy to explain everything in text, then I'm fine with email/text/etc. Phone works for me, also. I've built lots of cars and helped run a shop, so I'm not a complete dunce, I just don't THIS car. It does have a way of making me dumb LOL
I've had a few people in my town promise to help but then flake on me. I just want to get the car finished so I can enjoy it again. It's beyond frustrating to have a car so close to being done but sitting and collecting dust.
Anyone willing to help me out? I'm hoping to have it done Thurs Apr 18 or the 19th. Short notice, I know, but I leave town for 10 days on Sat and would sleep better knowing the car is wired up first.
Please let me know ASAP. Thank you, in advance. Pictures of resistor, alternator post, and water pump port:
