68 HEMI GTS
My rpm manifold is completely un-modified.
Probably a bit of room for improvement on that with a little work.
For a street car a TM6 would work well. I found the throttle response could be made great. Takes a little tinkering. My low deck 451's did well with the TM6. I welded the silly bolt notches & ported the runner straight. It was a very good manifold. Although probably near the modern stuff.
You see any difference from eliminating the notches? I've thought about welding mine.
As I recall, nearly a tenth. In the day, that was a surprisingly good manifold. I'm sure today's tall manifolds produce more power, but you're fighting hood clearance.
The Holley Street Dominator is not your run of the mill single plane. It is small runner and a very GOOD street manifold. At one time was as good as you could get. Don't confuse it with the big port modern stuff for mild applications.As most said alot depends on the combo but I can give you some results from my sons Dart with a 400 in it. Its a 400 with Eddy RPM heads and the MP .557 cam and uses 3.91 gears. Its a pump gas street car and weighs just over 3600 lbs with him in the car. He ran 11.59 @ 117 with the single plane Holley Street Dominator. With the Eddy RPM he ran 11.55 @ 116 mph. You could see on his timeslip it was a faster 60 and 1/8 with the RPM intake and even though it had more mph with the single plane it was not enough to et as good as the RPM did. He also says it just feels much pepier at lower rpm with the RPM intake. He has since worked his et down to 11.41 @ 117 still using the RPM dual plane intake. Myself I run the Indy dual plane on my 63 but its a street car with a trip to the track every now and then. Its run 10.70's but I have never tried a single plane on the car to see how it likes it. Ron
Doug
the street dominator is good, but it`s old school. read the big block intake comparisons on them. they ain`t that great.I run the Holley Street Dominator. I swapped it for an identical ported unit and picked up 1/10 and 1mph.
