Paul_G
- 9:17 PM
- Dec 24, 2013
- Surprise, Arizona
I have been getting this new to me carb dialed in on my 505 stroker. Bought the carb used and rebuilt it. The carb is a Holley based custom built 950 by Pro Systems. It had 76 jets in the primary with 7.5 PV, 90 jets in the secondary with a PV plug. MY AFR's were showing mid 14's at half pedal/low vacuum when the primary's should be at full flow. I drilled out the PVCR to the next larger drill size, went with an 8.5 PV to get the fuel a little sooner as well. I should have measured the drill bit but I didnt. I want the additional fuel coming from the PV, because cruise and light pedal AFR's are around mid 13's. Bigger PVCR helped a little but still lean. I went to 80 jets in the primary. My half pedal AFR's are now low 13's. acceptable for now. WOT AFR's are low 12's. nice and safe.
The engine; 505ci Trick Flow headed, roller valve train, Comp roller cam 234/240@50 .542/.539 lift with 112 LSA. Stock 4 speed, 3.23 gears, 255/60-15 tires, 26" tall
