Thanks 68rules, all the 3 seals I replaced are OK, the last seal is not leaking either, the problem is not the inner seal.
I Jacked up the rear end, took the rear tires off, removed hubs, the first thing I did is shaking the axle, yes shaking the axle and it does move.
It has enough play to let the oil out.
I new earlier my axle housing has been reworked, it does not look new.
I took measurements of the axle roller bearing O.D, and the housing I.D.
RH Bearing O.D 2.884"
RH axle housing vertical I.D 2.987"
========== Horiz I.D 2.985"
LH Bearing O.D 2.884"
LH axle housing vertical I.D 2.931"
========== horiz I.D 2.919"
So there is a difference of .101" to .103" in the RH side and .049" to .035" at the LH side.
Is it time to look for another housing?, what is the housing I.D, and what is the interchange or donor cars?.
