Has anyone considered the unorthodox idea of a turbocharged mopar four banger? 1st gen Dodge Dakotas had 2.2 engines (non-turbo) standard. Those engines have been installed in RWD vehicles before, so the RWD installation is a possibility. It would also be less weight than a V-8. It wouldn't be an easy solution but it might be possible. Personally I'm not going that route but I have been collecting parts (driveshaft, trans mounts,etc) to possibly convert my car to small-block power. I've been considering it and keeping my options open.
im gearing up to go full on 3g hemi. Any cars i get from here on out will be getting the modern motor. You can go from mild to wild depending on what you want, and if its fuel mileage you are looking for, use a mds motor with a factory tune. You will have ok power and decent mileage.Has anyone considered the unorthodox idea of a turbocharged mopar four banger? 1st gen Dodge Dakotas had 2.2 engines (non-turbo) standard. Those engines have been installed in RWD vehicles before, so the RWD installation is a possibility. It would also be less weight than a V-8. It wouldn't be an easy solution but it might be possible. Personally I'm not going that route but I have been collecting parts (driveshaft, trans mounts,etc) to possibly convert my car to small-block power. I've been considering it and keeping my open.
