IMO.....
The "CORRECT" plugs are determined by several factors: REACH, CAM, COMPRESSION RATIOS, IGNITION ADVANCE CHARACTERISTICS and probably, intended use.
The Champion J-11Y or Mopar P34P plugs are available on the internet and eBay. I've purchased a large quantity of P34P Mopar plugs at a reasonable price. The Champion RJ-12YC replacement, for the J-11Y is a broad based heat range and will perform well. Likewise Autolite AP-85 is a platinum electrode design, very reasonably priced and readily available, and work well. AC R43S / R44S will also give satisfactory service.
For my application, 1970 Plymouth GTX RS23V0A******, with a cam, high compression ratio and origional Prestolite dual point distributor, and Dana 60 4,10 gears and 4 speed transmission, I use either Champion UJ-11G (paladium alloy center electrodes non projected nose plug) or Champion HO-8A platinum center electrode moderate heat range, NON projected nose, both being 3/8" reach design. The UJ-11G plug is a moderate heat range designed for 2 cycle engines. The HO-8A was designed for Homelite 2 cycle racing go kart engines burning methanol and nitromethane and castor oil fuel mixture running at 10k RPMs. Why did I select these plugs??......they were available and inexpensive.....and most importantly.....they work extremely well and offer a broad based heat range....the small diameter center electrode heats quickly to prevent fouling yet prevents over heating (due to the alloy which conducts heat transfer due to incoming charge cooling effect better). Will they work for your application?......probably.....how available are they?....difficult but not impossible to find....moderately expensive ($5 - $6 each). Both AC and Autolite will work well also.....but....you've got to try a brand name (what ever that brand is) and heat range to establish a base line starting point to be able to make comparisons either up (hotter) or down (colder). What works for me may/may not work for you. I'm sure others will have their own preferences and opinions. Points to ponder...
BOB RENTON
