damn, too much words and nothing conclusive really said!
first OP hasn't specified the exact setup he has
second OP hasn't said what's the exactly failure
Starts up and stall ? stalls while running the car ? never starts up ?
now, about MSD coil ( blaster 2 ) and Chrysler electronic ignition match. This setup has being run for YEARS on dozens of cars ( including mine ) without a failure related with ballast at least. I have used dual ballast with primary 1 ohm and the "MSD" ballast which is 0.8 ohms. Working good with both. Some pieces will match better than others but doesn't mean will fail.
OP has tested all ballasts and all read good! so IS NOT a ballast issue.
I bet is a WIRING issue.
Bulkhead connections ?
Pickup coil plug connection ?
ECU conection?
some wire internally broken ?
do you have the brake ( and oil if is the case ) light(s) on cluster dimming while cranking ? or do it turns off ?
Do you have voltage at ballast with ign key in RUN ?, do you have the same voltage at blue with yellow trace wire on ECU plug ?, the same but lower voltage at + lead of coil ?
Can you check for continuity in dist wires at ECU plug ? ( it should be on 150-900 ohms rate, but tipically goes on to 250-350 rate )
4 pins or 5 pins ECU module ?
is the ECU correctly grounded with chassis ? you can check it like this:
