Sorry, but that is incorrect. The red wire to the starter relay "BAT" terminal is 10Awg and the red wire to the starter is 6Awg. The brown wire from the starter relay "Sol" terminal to the starter solenoid is 12awg. The starter relay "I" terminal goes to the ignition switch and is 18Awg. The starter relay "G" terminal is soldered to the relay can for a manual and an automatic has a terminal for a brown wire to the neutral safety switch, also 18Awg. The manual shows the starter solenoid will draw 8-9A @ 6v, which gives approximately 700mOhm for the coil. 12v/0.7= 17.4A and the 12Awg wire is rated at 20A. All of this disregards the resistance of the wire for simplicity. The wire from the battery to the "BAT" terminal on the starter relay has a 12Awg fusible link, so basically, there is no way that wire operates or can even handle 60A...
