Beautiful Big Block Trick Flow Heads
Ok but when you order Trick Flow you pick the spring you want and that's what it comes with .
330 @ 700 out of the box (before you give them a touch up) would be hard to match with a worked Stealth and you will be able to go to Max Wedge port later if you wanted.
One more thing, the finish on the Trick Flow heads are 10 times better than Stealth, but Stealth's are the go if you want that painted stock look .
Each to there own but I'm looking a set right now and they look great. Might get the young gun to buy some for the VG Valiant.
On the same flow bench the CNC Stealths flow 305 cfm @ .600 lift. The Trickflows flow 316 cfm @ .600 lift. Very negligible difference in flow throughout the RPM range.
I like them both and would have no issue using either one.
Like the guy posted above, angled vs. straight plug is a consideration.
When all is said and done the pricing is very similar.
