Best 727 tranny rear mount?
69 GTX
9:42 PM
Milo, Iowa
I'm wondering if there is a preferred trans rubber mount? I'm going to run a Gear Vendor with it if that makes a difference.
For 69 440 GTX Street/Strip
I just found one on Ebay for my 1969, it was the 2 bolt model, not easy to find!
Kern Dog has some insight into this question. He re-drilled his trans crossmember and installed a spool mount. I just went through a Gear Vendor install and have stayed with a stock type mount from Brewers for now, but I also purchased the same spool mount and will likely switch to that next time the car is in the air. Look on my 80 Grit thread for pix of the install and the mount types...
http://www.forbbodiesonly.com/moparforum/showthread.php?36174-80-Grit!/page6
