thebankerstoy
A good set up for a mild street build like I think that this member is looking for, that also won't break the bank would be a set of the original cast iron 452 castings that have the hardened valve seats that will handle the crappy pump gas that we get these days. Put a good 3 angle valve job on them and a set of the standard sized Mopar Performance intake and exhaust valves, along with a set of the Mopar Performance Hemi valve springs, along with a new set of keepers and related hardware. A new set of good qualityvalve seals are also needed. A new set of chrome rocker shafts and a set of the Mopar Performance stamped steel Six-Pack rocker arms will be good to go to 6500 rmp range. I would also replace all of the attaching hardware.
As far as head porting goes, once again, it sounds like this will be a pretty mild build, so I wouldn't do anything other than to match the intake and exhaust ports to the gaskets.
Nothing fancy, but a set of heads like these will be perfect on this style build and won't break the bank either.
Richard
Richard
