AMX364
I always set preload with intake off. PITA but I can see what is happening. Really, really PITA on a Ford FE.
There is no such thing as a "best stock street cam". Pick something and try it, you'll learn what you think is best.
this is correct. too many variables to pick one profile and think it's good for all purposes. cam profile selection can be as foggy as picking converters.
Both these statements are true. A good lesson from Steve Dulcich here is to take the stock specs of what Mopar originally put into the motor, and add no more than 10% of stock duration. And add no more than .050" to the stock lift, you will have a very sweet street engine that can use a/the stock converter. I did this to my 383 and yeah, I'm real happy. My spec were more like 7% dur and .040" lift added to the stock numbers.
When my rr was originally built by my dad he put a .484 purple shaft in it. After a few weeks he changed it out to the .509. It runs a lot better now, especially with the 4.56 gears. I'm running 3000 stall manual valve body with 29x12.5 m/t sportsmans. I did have a 4.30 but I like the 4.56 better. I'm also running stock valve train with ported 906's. I shift around 6500 rpm. When it was my dads he shifted around 7500-8000 and put a pushrod through the rocker.
