I'm not going to into some pissing match, about Iron vs Aluminum
or one specific head or specific dealer is the better than anyone else
There are a ton of threads all over FBBO, many by
@IQ52,
he's my go to advice guy now as it comes to Mopar heads/porting
professionals/experts/Mopar engine builders, great guy too...
I trust him & his opinions 100%, I can't say that about many people...
Use the advanced Search feature, above on the right,
do your own search, lots of great threads/posts...
There are certainly better alum. cylinder-heads,
than I will ad here below, but no where near the same price points...
There is Aluminum Cylinder heads with a Max Wedge size style port too
if you want/need the bigger port...
Like the Victor Edelbrock is a great example...
I'm not new to building Mopars or Strokers, been there done that
I'm still learning everyday, I learn something else too...
I'll try to keep it somewhat simple...
IMO humble opinion of the "mid price point alum. heads",
not extreme or hi-$$$ stuff, best bang for the buck
I'd go with
Edelbrocks RPM's 75cc or 84cc 1500-6500 RPM or
even maybe the E-Street's idle-5500 RPM 75cc or 84cc,
depending on your pistons compression ratio etc.
or what cylinder head gaskets you use,
will effect static compression {or quench area} drastically
the ports are very similar on both versions
291cfm int & 217cfm exh. @ 0.600" gross valve lift
you can get the RPM's equipped with different springs too
fro hydraulic rollers & hydraulic flat tappet alike
IIRC the E-Street's have hydraulic flat tappet style camshaft
valve-springs installed
check out Edelbrock's website 1st
E-Street
http://www.edelbrock.com/automotive/mc/cylinder-heads/chrysler/e-street-bb.shtml
RPM
http://www.edelbrock.com/automotive/mc/cylinder-heads/chrysler/performer-rpm-bb.shtml
American made founded right here in SoCal, still doing it today too
American supplied, parts, valves, retainers, springs locks, seals etc.
I haven't tried the Trick flows yet,
seen some great results on them too...
Most the other brands mentioned here, are cast in China or some other "Knockoff" type deal
I don't have 1st hand experience with, to make a proper or honest assessment...
I try to buy Made In America 1st & foremost, even if it's a bit more...
INDY has great product too, a tad bit pricey for the most part
{or will expensive special valve-train etc., not all but most}
also, I'm not sure they have something in your budget range,
sounds like your doing it on a tighter budget...
& IMO
their customer service thru them sucks ***
If you buy INDY heads buy them from someone other than INDY,
like Mancini Racing or someone else...
It's Long story...
I had early versions of the Stealth's they didn't flow anything like advertised
only 250cfm IIRC about what a mild port job on a Cast Iron head would be...
After fully porting I got {my head porter Mark Lowe} 330cfm out of some...
I had a bad experience with the Stealths, combustion camber etc., long story...
but 440source.com made it all good, stood behind their product,
I ate the shipping costs, small price to pay IMO...
I have no issues with 95% of 440source.com parts,
especially the Made in USA stuff/Platinum series...
I've used a bunch of their stuff, in several of my stroker builds...
Wouldn't hesitate to use them again too...
The stealth's can be painted & to look a bunch more like
an OE iron head does...
They also have a Super Stealth with MW ports, if you need that sort of thing...
BUT;
In my experiances the Out of the Box cfm flows on the Edelbrock RPM's
is better than most Cast Iron 906/452 etc. Ported Heads {unless it's taken way out &
more flow than the Stealth's prior to fully porting too...
I hope some of that rambling actually helps you make an educated decision...
Good luck
