Moparmatt72
Just wondering if there is a big difference between these two cranks, are they comparable in strength and durability?
try to find somebody you can talk to about grain structure. a billet cuts the grain. the grain should flow the length of the crank in a forging. billets are more of a custom item for journal sizes or strokes that aren't readily available.What about over 1500hp? I talked to Callie and they don't make billet cranks, they actually said that a forged 4340 steel crank is stronger than a billet one. In order to make a billet crank as strong they would need to go to a different material. I kept the email about this.
Do you have a lot of disposable money?
aluminum rods >> not a good idea..
billet crank >>>>> Most expensive you can buy.
We make 1500 hp on Callies forged crank and rods..
We start with the Compstar and work our way up to the magnum XL depending on the application and hp going to be made. We specialize in LSx motors but and engine is an engine is an engine
No I don't have disposable money, just getting things at a deal getting lucky. The reason I went with a aluminum rod was I was talking to my machinist and they suggested going that route, they have built a lot of engine with aluminum rods. Lightens the rotating assembly plus absorbs some of the force. The shop is very rebutable out here.
Budnick ill be on twin turbos with meth inj to eliminate running a intercooler and running 110 race fuel. Ill check those companies out, callies turns out does make billet just not 4340 more like 4240 billet. I'm just trying to do research to find out what route to go with, I know it will take time to save for parts, I just want it to last being a strip but see street and cruise on the street too. I want to run 8.50s to high 7s. I'm doing this all on a blow through carb set up, would like to see how fast I can take it but that will be over time.
