Tylor
Thank you much. That's what I was needing to know. Whether I needed new piston if I were to bore it out. They some salt in these commentsTylor, take the block to the machine shop, hopefully experienced in high performance builds. They will measure the cylinders and determine how much overbore is required. Go with the smallest overbore you can. New pistons are required. Piston selection can be complicated depending on piston material & size. If you want a drag motor, you want clean round cylinder bores.
