ckessel
One issue with cutting the shaft and using a joint. You no longer have any way to allow for unibody flex which the factory style coupler did. If using a joint, you'll need to use a telescoping shaft assembly to allow for the flex/movement of the unibody othewise something in the system has to give. You could pull the joint off the box giving you no control. If you are using a Flaming River, Ididit or similar column, you'll need the telescoping shaft since those columns pretty much end just past the outer tube in a double d configuration that gets adapted to what you need using their joint and telescoping shaft as the go between.
