Yep, its getting cold in the garage so its time to scale down a bit.The more you drive it, the more you like it![]()
I raised the front of the car again, started the engine. Now I had pressure!
Bleeding the system 10 times right/left slowly then 10 times really fast....checking the oil my heart sank a bit when I saw all the bubbles...remembering that post about red-line oil foaming....
....though I had gone quite aggressive on bleeding the system, so this could just be all the bubbles leaving the oil?
Yep, after some hard driving (As hard as I could on now icy roads) checking the oil again and it was smooth and clear.
And yes! This is the result I was after...and really happy to achieve it after all this work:
- No center slop, smooth steering. fast turning, full assist at idling in gear at 650 RPM and I regained full trust in controlling the car again, no wandering.
The box is dead quiet, it whines when reaching the stops but that is as it should be.
Together with my wheel alignment I can let go of the wheel in a hard turn and the steering wheel returns lightning fast back to center.
FUN!
The result is awesome.
Im planning to tweak it a bit further as the steering is now between a FFst3 and original, so a bit on the light side.
But this is where the shims come in, correct? Adding some shims would make the steering a bit heavier.
Yes, like I have said before, my car has the full package, power disc brake, sub frames, hotchkis everything, ias shocks, hd leafs, bigger torsions, etc etc and etc.For some reason this comment reminds me of YouTube geniuses who need to let everyone know these cars don't brake, handle, or steer well. Like anyone who cares about performance is going to be using 50+ year old factory components.
Back in the early 90's, I met a gent who worked for King Richard. He was telling me stories of how the did alignments of the cars and what they did to get the bump steer ironed out. If it was needed, out came the hot wrench to heat up the lower balljoint/Pittman arm/idler arm to get what was needed. Over 180mph and lived to win. Don't think the Fiat's could take that kind of fix and live.I'd like to drive a well-built B-body back-to-back with a Ferrari 456 or Scaglietti. I've been watching old NASCAR and after seeing the cars in the 190's or higher (highest I've seen so far is 212 mph) I'm questioning the performance credentials of Ferrari and Lamborghini. I'm thinking a built B body is at least a match for the 456 or Scag. The 68-70 Charger will certainly win in the looks department.
Its a personal pref.I grew tired of the high resistance of my Firm Feel Stage 3 with Fast Ratio arms. When I swapped in my Borgeson, it was a nice change.
I had not heard of anyone that went back and shimmed their Saginaw once they installed a Borgeson. I've been under the impression that the Borgeson needs all the pressure the pump can make.
The slop is very small and yes, many years have passed since my rebuild and I have driven it quite hard. So something giving up in the linkage could very well be the case.I don't notice any slop in my Borgeson. Maybe there is a point where turning the wheel a few degrees either way from center results in no tire movement but it must be very small in mine. There are a lot of things that are involved in the steering linkage. Tie rod ends, pitman and idler arm ends, steering box mounting bolts, wheel bearings....if there is excessive slop in any of those things, it will add up.
The problem I had with the Firm Feel Stage 3 was that it was hard to turn at all points except in the center slop where it was like the tires were hanging in the air. Imagine it feeling like you're on ice with zero resistance in the wheel, then it is the next thing to manual steering. It made for a really crappy feel.
I don't blame Firm Feel entirely. They do what they can with a flawed design. Also, my Idler and Pitman may have some slop in the ends.
A stock Mopar steering box is so overboosted, you sometimes can barely tell the slop in the center since it is easy to turn from lock to lock.
Jigsaw has a decent standard Mopar steering box with Fast Ratio arms. It feels pretty good, to the point where I see no reason to change it out for anything else until it starts to feel loose.
Regarding the Saginaw pump and Borgeson box...I thought that I read from Bergman that he said that the Borgeson needs more boost than a Mopar unit.
If you were able to modify yours to get you the feel that you want, that is great. I just reused the same setup I used before with NO shim in the system.
