Mark1972
For context, last year I had this problem. After many hours of sorting through everything, I found the signal switch wiring under the steering wheel to be the culprit. A wire that is riveted on came loose and touched another wire, causing the brake lights to stop working. A little solder and problem solved. Now, yesterday to be exact, after a nice drive I backed into the garage and found the rear brake lights not working. The rear hazards either. The signals both work, and all front lights work fine. The rear bulbs are dual filament, and are fine. There is obviously power getting back there to power the signals. I checked the wiring under the steering wheel again and it's fine. I checked the brake pedal relay and it's fine. I don't know where to go from here. Any thoughts?
