Yup, like Ed said..
Doing this method, does that mean you don't have to bleed the master beforehand?
Yup, like Ed said..
LoL,
Wanker haha
Are you going to try this process on your Motor Mar?
LOL Indeed I am, Bry. Syringe is on it's way!
Well, I tried the revers bleeding & no matter how much I pumped fluid into the wheel cylinders, nothing would make it into the master. I ended up disconnecting the lines and bleeding the master, then pumped fluid from one wheel cylinder (front and rear) until fluid came out the (still disconnected) lines at the master. Then I reconnected the lines to the master and bled each wheel conventionally, with the aid of Submit pumping the brake pedal. Had I just bled the master and then bled the system one wheel at a time the conventional way, I think that I would have been better off because any fluid I pumped into the bleeders ended coming back out anyway once the upstream air in the lines came through.
You didn’t accidentally have the master cylinder lid clamped down did you?
Nope.
....I'm totally doing this.....Best brake bleeding tool for an empty system ever....
Don't even put fluid into the master cylinder, bolt everything together dry then start in the right rear & pump about ten squirts in through the bleeder screw and tighten the bleeder... Then move to the left rear & pump until fluid shows up in the master cylinder...
Then move to the right front... And pump til you just see fluid show up in the master cylinder.... Move to the left front & repeat... Top off the M/C... Go drive the car, your done...
