nick
Just wondering if any one knows the length size of the break cables for a 1969 roadrunner. bought some but wrong size. I think one cable is longer than the other. Thanks NICK
As long as it reaches and the housing to cable ratio is the same, your fine...If the whole assembly is too long, find some extra space to tuck the cable. Either way, if it was a longer cable or a short one, it will still pull the same amount and engage the shoe's just the same as long as it seats correctly at the split of the main cable and into the drum backing plate. If you're going for correct look/fit, well..I guess you'll have to reorder.
Good luck!
