mopar 3 B
Thought about that to but a good flasher will not flash without both bulbs working.Bad flasher
the ground got my rear lights working but no flash from the turn signals or hazardsWhat back lights are coming on? Turn signals will not blink till bulbs on both ends come on. Do the brake lights work? Do the hazards work?
All the lights are on. No flash anywhere thoughSure sounds like ground problems. Also I have seen a bad flasher flash one side & not the other. Check all ur lights again, frt&rear one at a time; process of elimination.
Stop and turn bulbs are daul filament. Only why to get turn signal, brake or hazard light to work is to activate their individual switch. All three go from the turn signal switch to the tail lights. All three power the same bulb filaments. Start with hazard wireing first. Powers all bulbs of the same filament feed. If the hazards work the rear wiring is ok. May not be right but ok.All the lights are on. No flash anywhere though
